L-Bracket for S1RII
NFec
For a long time I am looking for a good l bracket for my S1Rii.
I really liked using a l bradket with my old S1R and this was always quite handy plus it add even a little bit additional protection.
The only dedicated L bracket I was able to find is this one:
Has anyone of your already some experience with this or other L brackets for the S1ii oder S1Rii?
Unfortunately Leofoto cannot sell that one in the US because of some patent issues. Which is odd, as no one else has anything for the S1RII/S1II available. As an aside, the battery grip for the S1RII wobbles a bit and never seems to be fully tightened.
Really Right Stuff is a US company that makes camera L brackets; I've had good luck with them in the past, but they don't make accessories for Panasonic cameras so I don't use them anymore. However they have a universal L mount that should work okay with the S1RII. If I needed one now that's what I would get.
In past for my S1R I bought this one by Amazon.
Not that versatile than the "Leophoto" model. But very precise made, without any wobbling of the battery grip.
I do use it in combination with a tripod and a 3D geared head - Benro GD3WH
The L-bracket do fit the 3D geared head horizontally or vertically - < YouTube demo >
Didn't find yet an L-Bracket for a new S1Rii model.
I found a dealer in Germany which had the bracket of Leofoto listed.
I placed and order and they try to get it for me.
I was already scratching my head why the l bracket is not even listed on the Leofoto US website, but sounds logical of there is somehow a patent thing open.
The RRS looks very good too.
I will report how the Leofoto thing is, when and if it arrives....
unfortunately I don’t see a bracket for the S1RII on the RRS or Kirk Photo sites. The only l plate I have found in all my searching is the Leofoto one, so I’ll look forward to hearing what you think.
It seems Leofoto do have several website domains for different regions in the world.
Typically the USA region website with less product offerings. https://leofotousa.com
General Leofoto "com" domain: https://www.leofoto.com/products_detail.php?id=1007
Related Leofoto Australia: https://leofoto.com.au/product/leofoto-lpp-s1rii-bracket-for-panasonic-lumix-s1rii-s1ii-s1iie/
Leofoto "net" domain (Europe):
German language: https://www.leofoto.net/l-halterung...uer-panasonic-lumix-s1rii-s1ii-s1ii-e/p,86767
English language: https://www.leofoto.net/en/l-bracke...for-panasonic-lumix-s1rii-s1ii-s1ii-e/p,86767
International sendings:
YouTube product demo:
Smallrig L-bracket:
https://www.smallrig.com/Cage-for-Panasonic-LUMIX-S1R-II-S5-II-S5-IIX-G9-II-4902.html
Off topic:
I came across it by chance.
But still want to mention in case other L-mount camera users are reading this topic and looking for it.
L-bracket for Leica SL-3
https://www.amazon.de/ZTIANFOTO-SL3...llverschluss/dp/B0DPKKF5B5?xpid=6cwTduBzy99iD
There is not dedicated S1(R)ii bracket from RRS. But the generic bracket shall work fine. At least that's what I saw in some forums in the Internet.
I still prefer a dedicated bracket to be really sure it does not wobble or so.
I use the RRS universal L-bracket on my S5 and have zero complaints. It's good kit, with no wobbles at all.
I've been using the S5II Leofoto L-bracket on my S1RII on a regular basis; works fine overall, although the vertical part of the bracket has a slight interference with the S1RII's upper lug (near the drive dial) and thus you cannot completely snug the vertical part up against the side of the camera body. And, the vertical part is a touch too tall.
So yes, Leofoto's S1RII bracket - as demonstrated in the video above - would be a better choice, if it's available in your region. It's not on the USA website however, so I use the S5II L-bracket. Which, again, mounts very securely and supports the camera properly for both landscape and portraits orientations.
I did finally order the Leofoto S1II bracket from B&H. As one would expect, it’s perfect fit on the S1RII, although I did have to tighten the two screws that secure the vertical section to the lower section. They were slightly loose from the factory.
