Leica and Voigtlander M lenses on Lumix S cameras!
I rarely use it wide open because I shoot landscapes with it. I can compare it to the Sigma 24mm f/3.5. The Sigma is a bit smoother across the field and also has good contrast, but it doesn't have the same great sunbursts as the Voigtlander. The problem is, the 24mm is neither here nor there for me.
p/s I duplicated it on another host. Honestly, Flickr is really messing things up.
Looks much better! Good with S9... Hoping the S1RII will perform with a 28mm F2.8 color skopar. Have not found anything discussing this sensor with short VM lenses yet. After seeing the improvement of my 40mm F1.4 Nocton Classic on the S1RII compared to my S1 and results like this on the S9 I'm getting close to buying one even if the wide apertures suffer. The 21mm is tempting as well. Having compact lenes on a lighter more compact body means my camera will carry with me much more often.
The 21mm f3.5 from what I have read shows the least degradation of the VM wide lenses with Lumix cameras. I'm tempted to try this on my S1RII. Even if it is lacking at wider apertures. Having compact lenses means I carry my camera much more frequently. 28mm color skopar may be worth it as well due to the lack of L 28mm lenes.
