I have read that SD is better for thermal management in the camera because it generates less heat, but, it is slow, therefore takes longer to write/read to/from the card, then, is less heat but for a longer period of time.
On the other hand, CFexpress it is know that run warmer and generates more heat, but, it is fast, therefore the write/read operations are quick and even though generate more heat, it is for a shorter period of time.
Bottom line, what option for photo or video is better to reduce the overall heat in the S1 IIE, use SD or CFexpress? Thanks
